1st Gen R53 Cooper S Boost and coolant leak
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by ArcAngelS13, Nov 14, 2015.
  1. ArcAngelS13
    ArcAngelS13 New Member
    Nov 14, 2015
    Im trying to figure out an issue before throwing money around lol there is a boost leak or sc issues that only getting me 2.5-3 psi about 5-6 less psi than when it was originally. There is also a coolant leak somewhere but its not getting on the driveway but I can smell it and have to refill it every so often. This is my first Mini Cooper and would love the help.
  2. BlimeyCabrio
    Coolant leak is most likely the thermostat housing or gasket. Common problem, allows just enough coolant to leak that it pools on top of the transmission and evaporates off. Requires replacement of housing and gasket, not expensive. Use OEM.
    Secondary possibility is the water pump seals are failing. They do over time. The water pump is built to weep a tiny bit when new, and has a little reservoir that catches the fluid and allows it to evaporate without spilling out. But eventually the water pump seals allow enough coolant past that it will run down the front of the engine block.
    For a boost leak that large, it's most likely a torn or leaking intercooler boot. Could also be a faulty bypass valve, or even a small hole in the intercooler.
  3. 00Mini
    2,227
    You just got some great answers and Welcome to Motoring Alliance and as you can see the onlyest MINI Forum you'll ever need !!
  4. ArcAngelS13
    Nov 14, 2015
    Thanks for the help been trying to figure out what it was. Left the car at a friends dads house while deployed and it sat for 6 months when he was supposed to drive it every so often.
  5. Minidave
    4,587
    You'll get more accurate info if you tell us what car you have - and it also helps if we know what part of the country you're in...
    Welcome to the forum!
