1st Gen R53 Cooper S Brake lights and dash on, keys out
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by CptRadical, Jan 1, 2015.
  1. CptRadical
    CptRadical New Member
    Jan 1, 2015
    Happy New Year!
    I'm new here and hopeful one of you have the answer I'm looking for.
    My Mini suddenly has an electrical gremlin.
    Coming out to my 2002 r53 to go home after work yesterday, I saw my brake lights were on. The dash lights were also on as if the key were in and turned on (position 2, I guess). The lights were switched off and the keys were in my pocket.
    It sat that way long enough during the day to keep it from starting.
    It seemed to be fixed temporarily when I got a jump start, pulled the ignition fuse, turned the key on, then replaced the fuse. I'm not sure if the boost or the other action was the key ingredient or what.
    Today, the dash lights and brake lights came back on while sitting parked since last night. The battery is now too low to turn the starter over. I've left the battery disconnected for now.
    I should also mention I had the fuel pump replaced a couple of weeks ago. The plastic end had split and it was spraying half the fuel out.
    My thoughts point to the ignition switch, moisture in the bc1, or just a low battery. I pulled back the trim panel to look at the bc1 today, but didn't take it out. It seemed pretty dry down there, but the rubber door seal did have some moisture under it. The Mini has sat in some heavy rain the past couple of weeks, but not driven in it.
    If anyone can point me in a direction, or rule out anything at all, I would really appreciate it.
    So you still have the 12 year old OEM battery in the car?
    I think I would be looking at replacing the battery.
    Check the battery and charging system first. MINIs do voodoo stuff when electrical is not just so.
  4. CptRadical
    Jan 1, 2015
    It has a Duralast Gold in it that's been there since I got it a few years back. It probably needs replacing now that I've considered that time frame.
    I'll post back tomorrow night or Saturday with an update.
  5. Dave.0
    Yeah that sounds like it has seen the end of its life.
    I have an Optima Red top that has lasted years and use the AGM battery tender.
  6. nkfry
    nkfry New Member
    Roseville, MI
    Once you have had the battery put under a load test, (not just a CCA reading an actual carbon pile test) after the results come back I would suspect a failed BCM.
    Does the car have a sunroof? Are the drains attached and properly draining?
    It doesn't take much moisture at all to ruin a BCM, and the gremlins you're having sound exactly like the symptoms of a customers car we just replaced the BCM in about 3 months ago.
    If you have a local buddy with a known working BCM you can try switching them for a trial substitution, if it does in fact fix the issue you will need to buy a new BCM and have it coded to the car.
  7. CHKMINI
    Everyone thought my sons 05 R53 had a bad BCM when the same things were happening to his. Enter Marzo from Helix while at the Dragon last year. He diagnosed a shorted ABS harness where it comes through the firewall. It turned out that he was absolutely correct, repaired the harness and bingo....problems solved. I'm sure anyone else would have replaced the BCM first when it was never the issue.
    Also, remove your hatch interior panel and check the electrical connections at the license plate light assembly. They have been known to corrode if there is a water leak and cause the same issues.
  8. CptRadical
    Jan 1, 2015
    Update!
    I had a crank-no-start situation Friday. The crank sounded strong. Took the battery to the local auto part store. The guy said it looked like it ought to be strong enough. Up to now I was convinced it was the battery since the dash and brake lights went off after charging it a bit.
    The spark plugs looked OK. I didn't actually check the spark because the next day the battery was completely flat.
    I also found the driver-side (left) floor to be soaked with water. I think this went unnoticed for quite a while since it was under rubber mats.
    The carpet was soaked only on the flat bottom. I couldn't find any dampness behind the pedals or near the door. Passenger side appeared dry.
    Pouring water in the sunroof drains was inconclusive. It seemed to be draining fine, but i don't know. So my next step will be to pull back the roof liner to look at the hose in there.
    But I really think it might be the A pillar gasket. That exterior trim piece doesn't look like it was put on very well.
    I'll post a pic if it's light enough when I get home.
    Should I go ahead and get another battery, or just charge this one one up to continue the diagnosis?
    Thanks to everyone for the tips. :)
  9. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    Do a proper load test on the battery.
  10. Kenny kustom
    Jan 24, 2015
    297
    178
    I just did a load test on mine. Never had a problem starting it. Just wanted to check the battery. Looks to be original. ( 06).
    Failed. It only put out 50 amps @ 8 volts.
    Odyssey pc1200 is on its way.
  11. CptRadical
    Jan 1, 2015
    I did a load test after charging the battery back up. It only dropped to about 11.3V while turning it over. 12.76V with the key off, and about 13.1V before I reconnected it to the car after charging.
    I noticed a sticker on the battery that said "4/12" which I guess is its birth date. It seems fine for now.
    I also put my multimeter to the spark plugs and couldn't get a reading on two of them because the tip was burned down past the insulation. On the 20K Ohm setting, I got a reading of about 16 on one and 3 on the other. So I'll buy a new set of plugs.
    However, I don't think this is the source of the mysterious brake and dash light situation. I left the freshly charged battery on it, I'll see If they're on tomorrow. I'll also check the battery level.
  12. CHKMINI
    Put a new battery in it.......,
  13. Kenny kustom
    Jan 24, 2015
    297
    178
    That's not a proper load test.
  14. CptRadical
    Jan 1, 2015
    What is a proper load test then? Is it any more than measuring the voltage drop while turning it over for about 20 seconds? I have googled it, but that's all I came up with.
    I do realize the battery is at the end of its expected life, but I would like to test it properly.
  15. MCS02
    A good load tester puts a load on the battery it looks at amps and volts. Then it times the recovery time of the battery.
    Any parts store can do it for free. The cars are very picky when it comes to power, it's a BMW thing. On BMW's I have seen aftermarket light bulbs play havoc on the system.
  16. Kenny kustom
    Jan 24, 2015
    297
    178
    This is my personal one.
    There are better, but for the consumer, this works great.
    The one I use at work, can take up to an hour to fully test the battery.
    Sometimes it fails it in 5 minutes.
    Like I posted earlier, my battery still started the car.
    Yet failed the load test.
  17. MCS02
    Ooooooo look little pointy gauge things!!!!
    I haven't seen that in years. I like it! :D
  18. Kenny kustom
    Jan 24, 2015
    297
    178
    It's quick, it's easy, and under a hundred bucks..
  19. CHKMINI
  20. Kenny kustom
    Jan 24, 2015
    297
    178
    What a novel idea....;)
