1st Gen R53 Cooper S Does anybody run 5W-40 engine oil
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by rob76turbo, Feb 20, 2013.
  1. rob76turbo
    rob76turbo New Member
    Jan 18, 2013
    29
    17
    I know the specs call for 5W-30, but my wife's Cayenne and my son's GTI use 5W-40 and it helps if I only have to buy cases of one oil type. BTW, I use Amsoil, love the stuff.
    Thanks in advance.
  2. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
    The Pennzoil specified for MINI is 5W40. I'll switch back to that as soon as I can fix my oil leak and dump the Mobil1 I currently have in my MINI.
  3. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I swap between 5W-40 and 5W-30. I like 5W-40 but is harder to find. If I order oil I get 5W-40. I have had no issues with 5W-40. Seems like 5W-40 would be the better choice for warmer months. I usually use Redline oil.
  4. bmwr606
    bmwr606 New Member
    May 10, 2012
    62
    25
    #4 bmwr606, Feb 20, 2013
    mobil1 "european blend" 0W40 is a mini approved oil and it is readily available
    i use it in my cms all4 when i change the oil and have been using it for years in my 1997 gmc sonoma v6 that currently has 289,000+ miles
    scott
  5. Metalman
    I thought it was 0W-30.... Did they change it and I'm just finding out about it now???
    I run 0W40 in our MINI's. Mobile 1 flavored.....
  7. Jason Montague
    :cornut: I've always used Castrol or Mobile1 5W30 (extreme wear 100% synthetic) and MINI of DALLAS put their brand(Castrol I think) of 5W30 in Margi(08 R56 BRG MCS/JCWm) today during service warranty tune up. MM I'll trust your judgement. Research and let us know please. :Thumbsup:
  8. BThayer23
    The 5W-30 MINI oil is a thick 30 weight, which is why Mobil1 0W-40 meets the spec. So 5W-40 is probably perfect.
    I ran 15W-50 over the summer for a few hot track days, but I wouldn't recommend that, the car didn't like it at all on the street.
  9. Dave.0
  10. Austinsynthetics
    109
    44
    California
    #10 Austinsynthetics, Feb 21, 2013
  11. Metalman
    So there are kind of two camps here in the oil world as pertaining to BMW vehicle oil requirements.....
    Those that say they meet BMW oil specifications..... and those that are approved by BMW....
    Here is the current list as published by BMW....
    Synthetic Engine Oils - BMW North America
  12. RallyMini370
    While on the subject of oils. My Mini R50 is in Costa Rica so no cold temps(75F-90F) here and seeing as I'm rallying it the engine is going to get very hot. When I ran the Suzuki Swift GTI I used 10-40 but found the oil pressure dropped on a rally so I used 20-50 which cured the problem. Would it be a good idea to use 20-50 in the R50 engine for the rallies?
  13. Mr. Jim
    Hey Chuck, where is it? Under "news feed"? The link just takes me to the mobile site.
  14. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
  15. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    #15 BlwnAway, Feb 21, 2013
    I know it doesn't get cold there but IMO a 20w will not give you proper lubrication @ startup, I wouldn't go any heavier than a 10w, maybe you can find a specialty 5w or 0w-50, it may cost you a little more, but it's racing, "it's gonna cost you". :D
    Besides failures & such, one of the biggest factors concerning "normal" oil related wear is startup.
    Because of the miles I drive, I avg. 4-5 oil changes a year, for me it's 0w-40 in the winter & 5w-40 in the summer. (when I can find it)
  16. Metalman
  17. RallyMini370
    Thanks! I use race oil so I'll see what they have.
  18. Mr. Jim
  19. Metalman
    Weird.....
    I click on it and it's fine....
    Sooo am I the only one that get's to the site?
  20. Mr. Jim
    Well I'm using my iPhone, that's why I figured.
