1st Gen R50 Cooper Midland box final drive/gear ratio's
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by RallyMini370, Oct 23, 2012.
  1. RallyMini370
    #1 RallyMini370, Oct 23, 2012
    The Mini shares the same type of box as the Peugeot 106 rallye/GTI from Gripper UK you can get a lower final drive.
    MINI Cooper
    Gearbox Type 5-speed manual
    Gearbox MA5
    Tire size/ ratio 185/15/60
    Crown/Pinion Teeth 13x64 13x67
    1st Gear Ratio / Teeth 3.42
    2nd Gear Ratio / Teeth 1.95
    3rd Gear Ratio / Teeth 1.36
    4th Gear Ratio / Teeth 1.05
    5th Gear Ratio / Teeth 0.85
    Final Drive Ratio 4.7 5.1 3.97
    Max Speed (mph/7000RPM) in 1st 31 28 36
    Max Speed (mph/7000RPM) in 2nd 62 50 64
    Max Speed (mph/7000RPM) in 3rd 91 71 91
    Max Speed (mph/7000RPM) in 4th 116 92 118
    Max Speed (mph/7000RPM) in 5th 120 114 146
