Sprite Race Gearbox Rebuild
Discussion in 'Classic Mini' started by Minidave, Mar 18, 2021.
  1. Minidave
    4,584
    The owner brought this to me last November, saying it was his backup gearbox, so "no hurry". He knew I would be down for a while with my knee surgery.
    Since I'm kinda stuck for parts on my two engine builds I thought I would go ahead and get this knocked out. The tag on the gearbox says "broken third gear" and boy they weren't kidding.
    When you haven't done one of these for a while you forget all the little tricks you learned on the last one, so you have to learn them all over again - the hard way. This one proved no exception - I forgot you have to put it in 2nd gear before you try and take the mainshaft assembly out thru the back of the case or it fouls the reverse gear. Guess what I forgot to do?
    Ok, so here's what it looked like when I took the cover off....
    Yep, that's third gear missing almost all of its teeth. The layshaft fared a little better, only losing about 1/3 of it's teeth....I'm going to replace all the gears with straight cut rather than helical - these gearboxes were built for an engine making maybe 60 hp, they're now pushing close to 3 times that much!
    I started by taking off the shift housing and tailshaft assembly....the red rag is just there to sop up oil.
    I made a special tool to remove and install the bushing in the tail housing, but I can't find a reamer to make it to fit the shaft, so I don't replace them any more - they don't seem to wear badly anyway. I do replace the rear seal.
    Today, I managed to get the rest of the gearset out of the case. First you remove all the shift rods and forks - being careful not to lose any of the detent balls or pins. Then you drive the input shaft and gear forward - it won't come out of the case this way but you have to get the snap ring retainer off. Then you drop the laygear down into the bottom of the case by pulling the shaft out of it. Next - if you've remembered to put it in 2nd gear (which I didn't) - you remove the mainshaft assembly out the rear of the case in one big chunk. Then drive the input shaft back into the case till it's free, and lift the laygear out. The reverse gear shaft is held in with a threaded pin, after you remove that the shaft slides right out and the gear comes out easily.
    Once everything is out you can see the real carnage....
    Now, the REAL fun part of the job, removing the 2nd and 3rd gears off the mainshaft. To do this you have to press in a spring loaded pin, rotate the lockplate to match the splines on the shaft, then slide the lockplate up while not sending the pin into orbit never to be seen again. Installation is the reverse as they say - BUT - it is one bitch kitty to do! The other gear has not one but two pins!
    Maybe after lunch I'll tackle that......
  2. ScottinBend
    You have to wonder how they came up with these convoluted ways of assembly.....
  3. Minidave
    4,584
    10lbs of crap in a 5 lb box? :)
    • Agree Agree x 2
    • Funny Funny x 2
  4. Minidave
    4,584
    Ran into a snag on this gearbox.....turns out it may be either a Morris Minor box or has the guts out of a smooth case Sprite box in it. The mainshafts are completely different, and the gears are smaller too - probably why it broke.
    So, we're stopped for a while.
    Clancy says he has three "cores" in his garage and we can get what we need from one of them or simply rebuild one of them for Bugeye Dave's car, but he's out of town till Monday or Tuesday.....
    In the first pic you can see the pin I have to push in, so I can rotate the plate with the tiny hole it it till the splines line up, then I have to carefully lift that plate while not shooting the pin out from under it off into outer space. Once that's all out I can slide the gear off the roller bearings.......except this one has brass bushings! RuhRoh!
    Then when I compare the gears the inner diameter on the bad gear it's quite a bit smaller than the new ones - that are made to run on roller bearings. So - we need a completely different mainshaft - I'm hoping the case is the same for either one - and I think it is. Anyway you cut it I get to strip down another gearbox......
    Wait till you see the fun shenigans I get to have to get 2nd gear off the mainshaft - there are two pins, a top plate and two small plates under that! See the last pic.....
    • Informative Informative x 2
    • Like Like x 1
  5. Minidave
    4,584
    Clancy got me another gearbox, so I stripped it down and now have the right mainshaft to build Bugeye Dave's gearbox. More as it happens.....
  6. Minidave
    4,584
    Ok, so here's the difference between a smoothcase or Morris Minor gearbox and the later ribcase - BugeyeDave bought this transmission from Vicky Brits already rebuilt over 25 years ago. At that time it was just a street driven car and didn't become a full on racecar till much later in it's life - that's when it blew third gear to bits! So either they put smoothcase stuff in this ribcase case - which was not uncommon way back when as the case is a lot stronger too - or like I said, it's a MM transmission.
    So Clancy had dropped of another transmission earlier for me to rebuild but frankly I though the case was suspect - it had clearly broken and been rewelded and while it looks fine, I don't know that I would trust it to be straight and true. We decided to rob the mainshaft from it to use in BugeyeDaves trans, so I stripped down the new mainshaft so I could change the gears from helical to straight cut.
    In the first pic you can see it uses the same pin and plate arrangement as the earlier gearboxes, but when you get that plate off you can see a row of needle bearings - that's the big difference.
    That and there is a boss machined in the later mainshaft for the 2nd and 3rd gears to ride against that the earlier trans doesn't have, instead it relies on a brass plate between the gears.
    Once 3rd gear is off, I flip the shaft over and take out the harder plate - it has two pins, and some small half moon plates that ride under the pins and fit inside the plate on the top.
    It's a lot of bits to juggle around when it goes back together - but I've developed a secret way to get them off and on now. I use some assembly lube to hold the needle bearings in place on the shaft while I carefully slide the gear down over them.
    Then there's a pic of the mainshaft to show the assembly all done.
    Last pic shows the input shaft and laygear installed, however, to put the mainshaft in the case you have to pull the layshaft out of the laygear and let it drop down into the case so the mainshaft gears will clear those on the laygear. Once the mainshaft is in place then you raise the laygear back up and slide the layshaft into it, making sure not to drop the end washers out of place, cause they can bee a bugger to get back in with all the gears in place.
    After all that the next phase is to get all the detents and springs in place - I counted 5 pins and 2 balls that have to be put in the exact right place for them all to work correctly. Once those are all done, I'll put the tailhousing on and shim the rear bearing, then install the shift linkage and lastly I have to shim the front cover bearing too. Before I put the sidecover on I have some plates I made to hold the detents in the case while I shift it thru the gears to make sure they all work. If they do the side cover goes on and it's done and ready to race. Still a ways to go on this one.
  7. Minidave
    4,584
    Much better, this one won't break unless he does something wrong....
    What a lovely set of straight cut gears. This tread reminds me of building my last Spidget transmission. Make sure the detent balls are all there & in the right place. Oh man that one just about killed me. :Dead:
  9. Minidave
    4,584
    Yeah, they're pretty easy once you remember where they all go!
    I have all the forks in now, ready to shim the rear cover, then add the shifter housing.....should have it done this afternoon sometime.
  10. Minidave
    4,584
    Another Sprite race gearbox rebuild, and another third gear stripped - but this one is a straight cut gearset so I was surprised to see this. He said the last three events he had to hold it in 2nd and 3rd till 3rd finally gave up. I don't think I've seen one destroyed quite this badly...
    On further teardown I found parts missing, and parts lying in the bottom of the case that definitely don't belong there!
    and finally I found these broken synchros, which I've never seen one do before.
    My speculation is that the box was assembled incorrectly and went into two gears at once - at speed.
    I have all the new parts, and it's going to pretty much take everything to fix it! about the only parts I'll reuse are the mainshaft and reverse gear. It's a bit worn but you use it so rarely on a racecar that it shouldn't matter.
  11. 00Mini
    2,227
    That truly is a chewed up gear.
  12. old81
    1,542
    At least you have enought for the build, even if with a weak reverse. No biggie, not needed unless he is so far into the weeds a truck cannot get a hook on him.
  13. Minidave
    4,584
    Moving along on this gearbox build, I was able to find in my box of old gearbox parts a 1st gear, and 3/4th shift hub and a 3/4 shift fork to replace the damaged ones, I still need a 1/2 shift fork and I have one on order from Moss. Some of these parts have become virtually impossible to find.....case in point, the 3/4 shift hub is pretty much unobtanium new now - I did find one NOS in Va for $275 but I didn't buy it as I found a good used one in my spares. But, I may buy it anyway for a future build. The same place also had some 3/4 shift forks used but good for only $25 - I may buy a couple of those too.....no one has those for sale new anymore that I can find.
    So I got all the pieces parts cleaned up and ready to go back together.
    I started by putting 3rd gear in place as there's only one pin to address there, once that was on I flipped the shaft over and put 2nd on - which is VERY fiddly and takes usually about an hour!
    With that done I assembled the shift hubs - there are three springs and detent balls that have to go together to allow the outer part to fit over the inner. I use a hose clamp as I find its the easiest way.....it holds all three balls in place, then I smack the outer down over the inner and is shoves the clamp off as it fits in place. works a treat but it's a little tricky the first few times you do it - it's a good idea to encase the hub in a shop rag in case it doesn't go together - springs and balls flying everywhere if you don't!
    Old first gear, and new first assembled on the mainshaft
    After that I put the new bearing on the input shaft and installed it - it goes in from inside the case, then the retaining clip goes on the outside, and you push it back down into place. After that I put the layshaft in place with it's two washers and measure for end float - it was spot on. With that done the box is ready to reassemble.
    I need that shift fork before I can finish it up tho.....
    all the detents, springs and other bits that have to go in yet.
  14. Minidave
    4,584
    #14 Minidave, Aug 5, 2021
    Mostly back together now.....I found a 1/2 shift fork in my spares that looked almost new so I was able to go ahead with the assembly....
    I've bought gasket sets from three different sources and they all must get them off the same machine with a worn out die, cause this one gasket never fits worth a crap. I wind up using my little grade school hole punch to modify the holes so it will fit.
  15. Minidave
    4,584
    Annnndddd.........this one's done! Shifts nicely and feels solid.
    Time to start the next one (of two)
  16. 00Mini
    2,227
    Your rebuild projects always make for enjoyable reading.
  17. Crashton
    Building a gearbox is like doing watch repair. I've only rebuilt a couple. Been quite a few years & even back then parts were hard to find. I had to search long & hard for a lay gear.
    As far as spares go I'd pick up any NOS parts & good used ones you can find. A good friend & Brit car mechanic used to hit swap meets buying up any parts he could find. He rebuilt a lot of Spridget gear boxes. Seems most folks are afraid to tackle one.
    Nice work Dave. :Thumbsup:
  18. ScottinBend
    Be a shame if parts ever do become completely unavailable........time for someone to step up and start making them. :)
    • Like Like x 2
    • Agree Agree x 1
  19. Minidave
    4,584
    #19 Minidave, Aug 6, 2021
    You can find the odd one-off part made by somebody, but the costs are pretty high. MiniSpares has done a fantastic job of keeping the Classic Mini alive and on the road. You can buy just almost anything you need from them.
    Thanks for all the nice comments too - only they may have been premature - I had to take it apart again this morning, couldn't get it into 2nd gear. It seems there's a sticking detent somewhere. The good news is the only deadlines for me to complete these are in my own head.
    Darned detent balls really drove me mad on my first Sprite box of cogs rebuild. Seems one went MIA & I missed it. It would shift fine when tested on the bench, but once in the car it would shift into 2 gears at once & lock up the works. Argggg!@#%!! :Dead:
    Before I got out of Brit cars seems folks were putting 5 speed gearboxes out of Datsun B210's in them. I want to say it was a Rivergate conversion kit. These days finding a Datsun B210 transmission is probably near to impossible.
    Keep up the good work Dave. Hang in there you'll get it. :Thumbsup:
