Clear Coat Reaction
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Skidmarks, Jul 27, 2019.
  1. Skidmarks
    Skidmarks Active Member
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    after sanding, primer, sanding, three good base coats then a coat of clear, the second coat of clear does this...
    Grrr.
    10,036
    Looks like fisheye. Did you get any silicone on there before your final coat?
    Clean it with some prep-sol & then wet sand those away. Clean again & have another go. Sorry this happened to you. I hate body work.
    • Like Like x 1
    • Agree Agree x 1
  3. MCS02
    6,185
    I have had the same thing happen to me. But you can save it.
  4. Skidmarks
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Nothing between coats 1 and 2 but 30 minutes. Sanded again and giving it another coat of color.
  5. Skidmarks
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Just checked the work and it all looks like shit. I’ll let it dry and sand all the way down and start over.
    I love/hate painting.
    This all started today at 8am because I wasn’t happy with the finish I had. Sanded down and stared over, now it is worse than it was this morning.
  6. Dave.0
    Clear can be a pain in the ass sometimes.
    I always shake or mix the hell put of right before I spray and do short thin dusting coats.
    Also very important, HUMIDITY. I have had the same think happen to me. I painted a few things in the morning around 10 am or so. They later that night after a day of curing I forgot about the humidity and got the same results you did.
    I ended up wet sanding with 320 then 400 and shooting it again in lower humidity with great results. I spray several thin layers of clear and let them flash dry between coats with a little help from a heat gun.
    • Agree Agree x 2
    • Like Like x 1
  7. Skidmarks
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Heat gun is a good idea. Pretty humid today.
  8. MCS02
    6,185
    I have used my heat gun also just be carful
    10,036
    How do you load the paint in the heat gun? o_O
  10. Skidmarks
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Took it back down to primer and started again. Went great today and I got it all finished up. Now to do the other door.
    • Like Like x 4
    • Winner Winner x 1
  11. MCS02
    6,185
    Looking good!
  12. Jeff10049
    Jeff10049 Member
    Nov 24, 2019
    42
    62
    Also beware of contamination oils/water from the compressor I like to run one of the cheap little filters at the spray gun to catch anything that might get past other filters/separators.
    • Like Like x 1
    • Agree Agree x 1
  13. Jeff10049
    Jeff10049 Member
    Nov 24, 2019
    42
    62
    one other thing I thought to add interior parts can be tough to get clean if armor all or other like treatments have ever been used the stuff will keep coming to the surface right through the primer and base and fisheye the clear. If you don't get it all off to start with scrubbing the parts with ajax and hot water really helps.
  14. Dave.0
    Acetone or Lacquer Thinner take care off all that before you shoot your paint right before you tack cloth one last time.
  15. Jeff10049
    Jeff10049 Member
    Nov 24, 2019
    42
    62
    I have done that when needed but better to get it clean from the start if you can dusting coats of clear as you said can bail you out as well but the texture of that can haunt you to the last coat and require more sand and buff than should be needed to get a glass finish. Ideally, you spray your first coat of clear how you want it to look when done that said I do go a little easier on the first coat let it flash and hammer on coat two and three but you want that first coat flat if you can.
    Here is my 2004 after 3 full wet coats of clear needed almost no sand and buff zero fisheyes I had been treating the plastic molding with a product I knew would give me hell if not cleaned 100%. I started with a dawn dish soap hand wash then actone wipe down then pressure wash with Castrol super clean purple degreaser. Then a waterborne prep wipe down then solventborne prep wipe down before I started sanding. 20180215_181944.jpg 20180215_182023.jpg
    • Like Like x 3
    • Agree Agree x 1
  16. 00Mini
    2,076
    Looks sharp
  17. dNorman48
    dNorman48 Member
    Jul 24, 2019
    35
    17
    That's incredible result! Nice
