DSC light comes on occasionally
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by bcgreen, Nov 25, 2019.
  1. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    #1 bcgreen, Nov 25, 2019
    Occasionally the DSC light is on. I recently had my clutch replaced, serpentine belt changed and a 17% pulley installed and wondered if there is a connection. This service was done 6 days ago. Service Engine Soon came on this morning after the car sat for 1 and a 1/2 hours. No driveability issues.
    2004 Mini Cooper S.
    10,036
    Check the wire connections for the wheel speed sensors at the front wheels.
    • Like Like x 1
    • Agree Agree x 1
  3. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    #3 bcgreen, Nov 25, 2019
    Thanks, will check it out.
  4. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    could be dirt between hub and sensors. Takes a 10 mm wrench to pull them out, clean the tip, and then you can use a bunch of Q-tips inside the hole of the sensor to clean the hub surface where it meets the sensor (rotate wheel while putting pressure on the alcohol soaked Q-tip). I just removed my hubs entirely while doing the R56 aluminum trailing arm conversion and those magnetic (?) hub surfaces and sensor tips were caked with some tough black gunk. I never had DSC light issues, but it can't be a good thing when there is grime accumulating where a sensitive device is monitoring wheel speed. My car is generally super clean, but that's a place nobody ever cleans unless you disassemble stuff. 100k miles and the bearings in the rear hubs were also pretty much done.
    • Like Like x 1
    • Agree Agree x 1
  5. MCS02
    6,185
    Do you know if there are any codes showing?
  6. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    Good info
  7. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    Will go to O'Reillys.
  8. Dave.0
    Turn off DSC, you don’t need that “nanny” feature.
  9. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    Won't turn off.
  10. Dave.0
    Then it’s fine. I have had my DSC coded off for over 8 years. Yeah the little light is on but, I don’t care.
  11. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    What about "Service Engine Soon"
    10,036
    More than likely they won't be able to read the MINI code unless their reader knows the secret handshake.
    I agree with Dave about nannies in cars. My MINI didn't have DSC, I used the money it cost to buy the LSD. I'm thinking you may well need to fix your issue. The wheels speed sensors are there for the ABS to work & for me that's a good nanny to have.
    Service engine soon. Check what needs to be done by going into the settings. Push the button on the turn signal stalk & go through there. You should find it.
  13. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    Had a scan done and it read as P0340
    10,036
    That points to the camshaft position sensor. Not sure how you isolate if it is the sensor, the wiring or some other cause.
  15. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    This morning it was off as well as the DSC, for 20 min. then came on, along with the DSC. Code scan didn't indicate any issue with the DSC. I was hoping there would an indication as to what wheel is the issue.
  16. MCS02
    6,185
    The only way is to check all the wiring. Make sure the plug is clean and plugged in good. Also make sure none of the wires look like they have been damaged. Parts store readers don’t read the BMW/MINI DSC codes.
  17. MCS02
    6,185
  18. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    Looked at the plug and it looks good from the outside and is very secure/stable. Locked in, not loose in any way.
  19. dNorman48
    dNorman48 Member
    Jul 24, 2019
    35
    17
  20. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    Does only the DSC light come on?
    Or ABS, DSC, & TPM?
    Only DSC might be a faulty steering angle sensor. But not sure if the MINIs have one like our BMW brothers.
    Sent from my iPhone using Tapatalk Pro
