R56 I want to go from 4 lugs to 5 lugs.
Discussion in 'Car Builds, Projects, Idea's Experiments' started by DJBishopNYC, Dec 1, 2019.
  1. DJBishopNYC
    DJBishopNYC Member
    Oct 23, 2013
    41
    Can the r56’s 4x100 lug nut dimensionswheel bearings be switched to the countryman’s 5x120 with no mods?
    Anything can be done with enough money. Plan yo spend a lot.
  3. MCS02
    6,185
    I don't know sorry
  4. Minidave
    4,419
    That's a good question! I'll bet they will swap.....
  5. Jeff10049
    Jeff10049 Member
    Nov 24, 2019
    42
    62
    Unfortunately no they don't interchange. Nor do the rotors or any of the brake stuff.
    There might be a possibility of changing out the whole assembly as the struts are the same upper mounting not sure about the lower arm or steering though have to experiment.
    Then you still have the rear to deal with.
    drilling the stock hubs is a no go as there is not sufficient meat.
    • Informative Informative x 1
