Oil Leak at the Filter
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Skidmarks, Oct 19, 2019.
  1. Skidmarks
    Skidmarks Active Member
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Ron Swanson developed a severe oil leak and I found the issue at the filter.
    or the damaged O-Ring:
    Or both.
    I’m going to replace the O-Ring and see how that goes.
  2. Skidmarks
    Aug 12, 2017
    110
    161
    IT/OT Analyst
    Wichita, KS
    Had another filter kit- swapped out the ring and filter element and no leak now.
  3. MCS02
    6,185
    Glad it was an easy fix
  4. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    got to lube those o-rings really well before reinstall. Based on the resistance of the cap during install, I feel motor oil alone doesn't always cut it in that position and use some light grease on the fresh ring instead.
    • Agree Agree x 3
    • Like Like x 1
    10,036
    I always give that O-ring a lick of grease. I've changed the oil on a few friends MINI's & the O-rings were like hard plastic. When touched they crumbled. I asked them when was the last time they had their oil changed. Turns out it was only 5,000 miles, but the flat rate guy at the dealer never bothered with a new O-ring. Oh man..... :Dead:
