1st Gen R53 Ported head alternative and possible 1.8 Tritec
Discussion in 'Tuning and Performance' started by Whine not Walnuts, Nov 28, 2019.
  1. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    #1 Whine not Walnuts, Nov 28, 2019
    I have a shop in Poland making some brackets and other parts for a ax1200 Whipple Supercharger I am now building after getting what I wanted from my M62 kits both of which I have sold.
    Early this week I was talking to the guy in Poland as he was chasing down a 1.6 liter Fiat E-TorQ head that he was pretty sure would work on the Tritec.
    This is not a r50 Tritec with a ported head but rather a Fiat 1.6 E-TorQ engine. Fiat purchased the Brazilian Tritec plant in 2011. The Chrysler Engineer that was involved in developing the Tritec had this to say.
    This is the 1.6 E-TorQ head sitting on top of a r53 Tritec head.
    This head bolts right on the Tritec with the valve cover, cam, cam gear, rockers, timing chain, and intake manifold also bolting up although the intake manifold does need to ported out.
    78421480_612667642806422_6114676078104543232_n.jpg re
    Through some Fiat contacts in Europe it was determined that the 1.6 uses the r50 crankshaft. Through pictures I found it appears the 1.8 engine uses a Siamese cylinder insert that eliminates the water port between the inner cylinders thereby allowing the use of the 1.6 block casting. This would mean the r53 crankshaft would work and that with the Siamese the engine could accept supercharging via forged rods and pistons. The 1.8 does not appear to have the proper bolt holes for the attachment of the supercharger snout.
    Both the 1.6 and 1.8 share the same stroke as the Tritec with the 1.8 bore increasing from 77 to 80.5 mm. I have reached out to Wiseco and CP on if they would make a MINI piston in this 80.5 bore. With the r53 crankshaft, forged rods and a 80.5 piston the only items remaining are confirmation of the transmission bolt lug spacing and the spacing of the timing chain/oil pump cover. Fiat uses Aisen transmissions and as the Tritec used both Aisen and Getrag the possibility is strong that the Getrag will mount to the E-TorQ.
    The 1.6 head should have different type valves installed to handle forced induction pressures. The head was successfully installed on a r53 and will be flow bench tested once valves are changed over. The 1.8 engine is used in Latin and South American where in Brazil it is an alcohol engine. I have found new short blocks for a little as $1250 US that does not include shipping.
    The Fiat/Tritec/E-TorQs have been out since 2012 and it is surprising that neither of these possible mods were ever attempted. Alejandro's comments are positive relative to the head and it appears this could be a low cost alternative to a "worked" MINI head.
    If you are interested in more information send me a PM.
  2. Minidave
    4,419
    Interesting that Fiat bought the Chrysler engine plant, because Chrysler and Fiat merged only 3 years later....in 2014.
  3. Jeff10049
    Jeff10049 Member
    Nov 24, 2019
    42
    62
    cool I have often wondered about the interchangeability of the various tritec engines and the latest e torq variant. That engine has roots back to the slant 6. I wonder what the export 1.6 neons might share with mini.
    Or what about the U.S. neons they were timing belt not chain but I wonder if the 3.98" stroke cranks could be modified some combo of rods pistons etc to make a stroked mini probably highly unlikely but would be fun to have the parts sitting there and play around with.
  4. Dave.0
    So you have failed yet again and now are having guy from Poland trying to use a Fiat block and head.
    I will say your commitment to failure hysterical. I love reading the post on FB with you and Coleslaw your Polish engineer. lol
    I can take screenshots also.//:D
  5. MCS02
    6,185
    Ok I am slow I know that so I read it twice. I am not really sure what your doing. So you are going to put a R53 crank in the Fiat block and run the Fiat head because you believe it flows better? What is the valve size on the fiat head compared to the MINI? Is this to save money also?
    You said that you found a short block for a little as $1250 US that does not include shipping. Allmeg has a long block for $1199.99
    https://www.allmagautoparts.com/collections/mini-cooper/products/mini-cooper-s-engine-supercharged-146k-miles-1-6l-2002-2008-r52-r53
    If you want a cheap big valve head find a good local machine shop that works on drag cars. They can build you one. When I did the big valve head on my X 1/9 the only place you could buy a big valve head wanted a lot on money for them. The guy that did all the drag cars in this area heard me talking about it and found the valves that were the same size. He charged me a little more than the price of reworking the head.
    At this stage I will probably just buy a RMW head or chose your flavor.
    Hope you don't think I am being argumentative because I am not. I am curious and would like to hear more.
  6. Minidave
    4,419
    wow, MCS02 the engine you listed has 146K on it!
    You built a hot rod X1/9? My son is in the process of installing a Honda K24 in his right now.....
    • Like Like x 1
    • Funny Funny x 1
  7. MCS02
    6,185
    It was long ago. somewhere around 82. I have heard about people doing the Honda conversion. I would love to do that. If he has a build thread going anywhere I would like to see it.
    I listed that engine because if he is going to put a new crank in the Fiat block you can get this head and all and rebuild it. Seems to me like you're not saving money on the Fiat. But I am not sure I know what he is trying to do.
  8. Minidave
    4,419
    He doesn't exactly have a build thread, just posts the occasional pic on Facebook...….He bought a subframe kit and has welded it up and got the motor mounts sorted at this point, still has a LOOOOONNNNNGGGGGG ways to go!
  9. ScottinBend
    That guy is an absolute train wreck........
  10. Thumper460
    Thumper460 Active Member
    May 26, 2009
    559
    94
    United States Navy ..Retired
    Why not use the stock 1.6 block, bore it 81 mm , sleeve it, get some pistons and rods, Head/cam and intake.. blower or turbo and have fun??
    This is a hobby with most of us , and all the info we can gather is a good thing. As the W11 is getting older there are more bits/engines available , making for more deeper mods. Whine not Walnuts is passing good info. And Over seas has been doing weird things longer... lol, yes?
  11. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    The Polish guy did get one Fiat head completed for a R53 and a woman in the UK bought it. He turned out to be a bust but there is a real alternative to the Fiat 1.8 and its a ductile iron sleeved Tritec that was put together by Thumper Performance and an engine shop that built engines for Don Garlits. I have one in my R53.
  12. Thumper460
    May 26, 2009
    559
    94
    Thanks.. Yes, the 81 mm Steel sleeved, Blueprinted Forged Piston H-beamed Short Blocks are out there now. We use the super strong and thin Steel Sleeves. JE Pistons and K-1 Rods. New Performance Silicon-Aluminum Bearings, Block is Decked, Crankshaft is Mic'd and then Polished. Could be the Future. 1.8 Kits and build 004.JPG
    • Informative Informative x 2
    • Like Like x 1
  13. ScottinBend
    :Vomit::Vomit::Vomit::Vomit:
  14. Thumper460
    May 26, 2009
    559
    94
    :Wtf::Wtf::Nailbiting::Nailbiting::Nailbiting::Nailbiting::Whistling::Whistling::Whistling::Whistling::Whistling:
    LOL who cares what you like. This guy is building and doing his modifications and showing what he is doing.Not just BS everyone .. or just :Vomit:, to every one other than your opinion !
    10,036
    #15 Crashton, Sep 17, 2020
    Oh boy, you have been gone for a while & things seemed go smoothly. You are back for a day & the BS starts. No need to reply I understand you don't care what other people think. Have a swell day. :Whistling:
  16. Thumper460
    May 26, 2009
    559
    94
    LOL.. I guess I could just sit back and let the 'Other BS' just roll with their crap. I think we all have ideas and should be able to post with out the TROLLS chiming in with nothing but BS . Yes I have been gone for a while because of just this thing.. SPSTFU ! Today is different, the short comments and avatars showing dumb answers should be called out.... show their experience and then Help the poster, dont show your ass and expect most to just sit tight and not respond. 'Merica !
  17. Minidave
    4,419
    I don't understand this Scott, who is this aimed at and why?
  18. ScottinBend
    Aimed at Whine...........this whole thread is useless. And based on his front brake upgrade, I would never trust any of his claims or build quality.
  19. Whine not Walnuts
    Mar 14, 2017
    359
    253
    waitin for my check
    Fuquay Varina, NC
    Bing Crosby was in a movie based on Twain's "A Connecticut Yankee in King Arthur's Court" and there was a part in the movie where I am pretty sure he used a Farmer's Almanac to get out a tight spot. Relative to my "front brake upgrade" I did not use an Almanac but I did use more than 40 years of construction experience that included understanding engineering related to steel. I also reached out to a friend that happened to be an engineer. He was not just some recent college grad working for a company making snow plow parts that happened to head up the College Race Car build or even a well known parts seller both of which are not licensed engineers. My friend is a licensed structural engineer that owns a consulting firm and like me has years of experience. If you know the difference between tension and shear along with PEMDAS you can do our own calculations and then render an educated opinion.
