Wheel size question! 2018 JCW...
Discussion in '3rd Generation: 2014+ F54, F55, F56, F57, F60' started by Beemerchef, Nov 21, 2019.
  1. Beemerchef
    Beemerchef Member
    Sep 25, 2019
    68
    Alamogordo, NM
    This is when I feel really ignorant! Oh! well...
    My tires are 215/40R/18
    I saw these wheels which are priced each at $130 with good reviews. I like the red stripe and the fact to be able to clean the red JCW brake assembly much easier! They weigh 23lbs each. Good?
    For the Life of me I cannot find the wheel size... Nowhere!
    I do know that the "offset" should be 35mm. The seller has not yet replied if it is available versus the 45mm advertised.
    So this is the two results I got which do not match!
    If anyone knows, I would greatly appreciate to pass on the info...
    Thank You much.
    These numbers are for the JCW
    • Agree Agree x 3
    • Like Like x 1
  3. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #3 Qik, Nov 22, 2019
    Nowhere? 23 lbs is HEAVY. As Dave said, like R112 JCW OE heavy. There's better options available but if weight isn't a concern.... Also better options than Motegi dual bolt pattern wheels on TireRack. https://www.wheel-size.com/size/mini/cooper/
  4. Beemerchef
    Beemerchef Member
    Sep 25, 2019
    68
    Alamogordo, NM
    Thanks... They don't make it in the proper size... which is good!!! I will look further and will take the weight in consideration.
  5. Dave.0
    Also, you can pinstripe any wheel.
    10,036
    I've seen people making their own pinstripes as they grind along the curb. ;)
    • Funny Funny x 3
    • Agree Agree x 1
  7. Beemerchef
    Beemerchef Member
    Sep 25, 2019
    68
    Alamogordo, NM
    Thanks for the thought!... Will work on that... :D
    • Funny Funny x 2
    • Winner Winner x 1
  8. N0B0DY
    N0B0DY Active Member
    Oct 29, 2018
    170
    70
    NM engineering makes wheels that fit over the JCW brakes. They also dont need any hub rings. I have the 17" wheels. They also have them in 18"[​IMG]
    Sent from my SM-N970U using Tapatalk
    • Like Like x 4
    • Agree Agree x 1
  9. 00Mini
    2,076
    Nice looking ride.
  10. Minidave
    4,419
    Not using centering rings is a real positive!
    Factory S-Heavies weigh about 25lbs each, and the only real thing going for them is that they are TOUGH.…..potholes don't faze them.
  11. Dave.0
    That’s why I have a set of S-Heavies for my Winter beater wheels with snows on them.
  12. Dave.0
    Here are a few extra pictures of that car after I detailed and coated it last year.
    F1326280-3A6E-4B51-A681-5FFA672C6C41.jpeg 731F101E-134C-4E01-9D4B-B9A9BF73E381.jpeg 82929226-FBBB-49A1-9DCA-0FEA8D006061.jpeg 32E61D6E-7915-437B-88A8-ED0BAD8705F9.jpeg E2F7661D-D6AA-4098-AEBD-DBDF52D5DCAD.jpeg
