1st Gen R50 Cooper Please Help! How to replace Oil Filter Housing
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MyklMacD, Aug 26, 2013.
  1. MyklMacD
    MyklMacD New Member
    Aug 26, 2013
    120
    Recovery Specialist @ WRC Telecare WRC
    Salem, OR
    Huh?
  2. MyklMacD
    MyklMacD New Member
    Aug 26, 2013
    120
    Salem, OR
    Well with the help from a friend I was able to finish this job. Took us several hours of reaching from the wheel well, under the car and around the axle, and from the top of the engine with the heat shields removed. Many !@#$ later, we got it off and somehow back on. no low oil pressure at idle and purrs like a kitten. Thank GOD! was stressin too hard.
    Glad you have it fixed
  4. RallyMini370
    sorry I read the end of the thread and posted I had a used one then skipped back to see you bought a new one....so I had to edit. Happy you got it sorted.
  5. MyklMacD
    MyklMacD New Member
    Aug 26, 2013
    120
    Salem, OR
    oh ok, I see. Thanks for the reply tho. This job was a pain in the ass, but it feels soo good to have it done with
  6. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    reviving this thread. I noticed my housing was leaking the other day on my 06, looking at the pictures you posted on here did yours have the cooler on there? and does anyone know if its possible to change just the housing gasket without removing the cooler?
  7. Dave.0
    #27 Dave.0, Jan 27, 2014
  8. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    Dave thanks for the info, my cooler is fine though. I was just wondering if I can pull the housing off the block to change the gasket without unbolting the cooler from the housing. I bought replacement o-rings but would rather not mess with it as its not leaking but I will if I absolutely need to.
  9. Dave.0
    Ahh ok. I don't think so but I am not 100% sure. Shoot Chad from DT a PM or give him a call tomorrow.
  10. BThayer23
    Not sure if you can take the filter housing off the block without disconnecting the heat exchanger. Just a warning, if you're going to take the heat exchanger off, get a pair of cable-operated hose clamp pliers. It's impossible to get the coolant hoses off without this $40 tool. I tried every set of pliers, had my friend help from above, cursed and swore, but nothing worked until I got the special hose clamp pliers.
  11. ScottinBend
    I don't think the Coopers had an oil cooler/warmer?
  12. RallyMini370
    Mine does! hahaha stole it from a "S" and did my own plumbing.
  13. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    BThayer thanks for the heads up I don't know how I would have got those lines off without the special pliers. My filter housing gasket and oil cooler gaskets are now replaced and I believe the leak has stopped, currently parking over cardboard to watch it.
    I wish I could say the job went easy, well it did, up until the point where I broke the little black plastic spring thing in the housing... That was an expensive mistake but I got lucky and Way had a used housing for me.
    Now I get to tackle a new leak I discovered while under Broknsmurf this morning.. looks like my power steering return line needs to be replaced.... Im starting to think broknsmurf knows im about to pay him off....
  14. mjlwriter
    mjlwriter Banned
    Jan 28, 2016
    36
    Researcher, Technical Author, Engineer
    Pacific Northwest
    The cage in early (R50) MINI Cooper Oil Caps (hard to come by)
    I have a 2002 MINI Cooper and am looking for a little information. I still have the original oil cap and housing. The cap has the OEM plastic cage that gets reused for the new filter with each oil change (to maintain oil pressure). After this last oil change, I noticed that the cage is in jeopardy of breaking because of the many times I've had to pry it out of the old oil filter; it rarely comes out easy.
    I could bore everyone with questions about the new style cap, whether it goes on to the old style housing, etc., etc. But, instead of that, I will just appeal to anyone who might, by sheer chance, have an extra cage laying around. I have tried to work with salvage yards, but since the part is so friggin' obscure, it's very hard to have at it.
    If you have a spare one you're willing to part with, please send me a private message. If there are any other solutions that don't involve changing out the oil housing, I'm open to that. My days of long repairs on the MINI are over, along with a bad back!...
    Any help?
    Thanks,
    Michael
  15. daviday
    daviday Active Member
    Jan 15, 2014
    140
    25
    #35 daviday, Dec 13, 2016
    Edited. I may have one from when My axle broke my housing. Will check for you tomorrow.
  16. daviday
    Jan 15, 2014
    140
    25
    Just read the other thread that got closed. I haven't changed my oil since I broke the housing off - I'm under the impression that I can't use a filter meant for an 03 now though if I'm understanding what I'm reading...
  17. daviday
    Jan 15, 2014
    140
    25
    Didn't even realize this guy was banned on Tapatalk. No dice anyway...
    I still remember cursing my way through this one. There's no easy way to do it. Three little bolts that are ridiculously difficult to get to.
  18. HELP
    HELP New Member
    Jul 24, 2024
    Bump!
    Hey all, I am about to attempt to change out the oil filter housing on my 2003 R50 (non S). I'm struggling to find any documentation on this job. I saw people mentioning cooler/coolant hoses. Does this apply to the R50, or is this just for models with a supercharger?
    Also, does anyone have any photos or diagrams of the oil filter housing? I can find plenty of videos of people changing the gasket on the housing, but none of them changing the housing itself. Is it much more trouble to change out the entire housing beyond swapping out the gasket?
    Any help would be SUPER appreciated, as my Haynes manual has nothing about this in it. Also, if anyone by chance happens to have a spare early model oil filter cap with the cage inside, please hit me up!
  19. MCS02
  20. 00Mini
    2,227
    Here’s a golden oldie answer that used to be given some years ago ….. if’n you’re gonna work on your MINI you should get a Bentley Service Manual.
    • Agree Agree x 2
    • Informative Informative x 1
